Board index » Big Squid RC Forums » RC Rock Crawling
Post new topic Reply to topic  [ 3 posts ]
 Post subject: I’m design a new comp chassis, need help.
 Post Posted: Mon Sep 08, 2008 7:43 pm
I’m design a new comp chassis, need help. Any tips or measurements will help. I’m running r2 trans with disconnect and wheely king axils. And also need to know what drive shaft ends fit best on the r2 out put shafts. Hears ware i'm go my inspurshoin for my new chassis.http://www.deanguitars.com/dean_winter_06/usa_rebel_razorback.htm I'm going to be using the head part for my base design.[/code]
 Post Posted: Thu Sep 18, 2008 1:05 pm
GOOD LUCK!!!
Download Solid Edge 2d then once your done with your design send it off to a waterjet cutter for cutting (water jet precision is great ask fo Carl and Tell him Jeff sent you)
Make your upper and lower links in a verticle line from each other 1" apart works great. Shock mounts usually work best between 7 1/2" and 8 1/2" apart.
Make sure you have a flat bottom on the chassis, as small as you can make it and still fit the trans. Make sure your lower links line up with your skid so you can use them like sliders.
Punisher shafts
 Post Posted: Thu Sep 18, 2008 4:04 pm
thanks jet for you input
Users browsing this forum: No registered users and 2 guests
