Post new topic Reply to topic  [ 10 posts ]
 Post subject: keep stuff out of my truck
 Post Posted: Fri Feb 11, 2011 3:32 pm
can any one tell me how to keep dirt and water out of my slash 4x4 without using an over tray cover?
 Post subject: Re: keep stuff out of my truck
 Post Posted: Sat Feb 12, 2011 7:29 am
outerwerea cover. its a cloth, not a hard plastic tray.
 Post Posted: Sat Feb 12, 2011 3:48 pm
thx for the info and because of it being cloth i wont have to worry about my running temp like i would if i had an over tray cover.
 Post Posted: Wed Feb 23, 2011 5:20 pm
can anyone please tell me how to keep my batteries cool? And im running the stock NI-MH 7 cell batteries.
 Post Posted: Wed Feb 23, 2011 6:31 pm
you might be over geared. if your batts are getting hot, knock a tooth or two off the pinion.
 Post Posted: Thu Feb 24, 2011 5:20 pm
well im running the stock 13 tooth pinion with the stock 54 tooth spur. But i was thinking of trying to use a cooling fan out of a computer to keep the batts from getting to hot.
 Post Posted: Sun Feb 27, 2011 8:44 am
check your drive line. make sure nothing is bound up and all parts are good. make sure you check the whole motion of the suspension. make sure nothing is jammed in the center tube where the drive shaft goes
 Post Posted: Sun Feb 27, 2011 9:44 pm
I clean my truck after every run. But im wondering if it has to do with the fact that im running 50 weight diff lube in the rear end.
 Post Posted: Mon Mar 28, 2011 9:17 am
Maybe your batteries cant supply the amps your ESC is needing. Are you running brushless? Ive actually had a Nimh pack explode in my truck from a brushless.
Head to Hobbyking or Hobbypatz and pick up a few 2s packs and a charger/balencer! A good Nimh pack cost more than lipo's now a days!
 Post Posted: Tue Aug 02, 2011 5:12 pm
Run a 12 tooth pinion
