Ok this will be the first time i have ever reviewed anything.
Straight out of the box the car really inpresed with it it's RTR ability is amazing all you have to do is charge the battery and go.
The cars stock back tyres are only good for getting used to the car no traction even on concret and the back swing arm's are the weckest iv'e ever touched. Myn brock after about ten run's and ten jump's and shatered all over the back yard leaving a huge mess
Then there was the fact of how fast a 20 turn photon speed motor can eat brushes i think that i will never stop buying brushes for it
Okay thats a enough beating on it now to get stuck into the good points first therer is the RTR capabillaty and if yop can get over the brushes the motor was beating my friend's T4 with a fireball 15 turn modafied in it
I just love the way the thing handel's on and off road if you want to drift you can if you won't to go in a strait line you can the stock controller is great two. It comes with coil shocks which work absulutly great on and off road.
Now into the testing i took it down to the local BMX track for a run and it went just as good as the bike's did i was really inpressd with it till it hit a tree and and the back sway are(the ather side this time) Shatered into 1 million peices and had to go home.
After it was fixed it was the jump test 1 metre high 2 long i di about 100 hundred jump's before the brushes fell out
then i said to my self it's a good car and all but it like's to break alot.
That was my first reveiw so sorry if it was a bit dodgey and fell free to coment and tell what to do next time
