AQUACRAFT VS1 COMPETITION WOOD TUNNEL HULL ARR
A proven winner of 10 National Championships!
From the prototype designed by Mike “Grimracer” Zaborowski that won the 2000 IMPBA Internats comes an unprecedented ARR version of the VS1 Wood Tunnel Hull that modelers can assemble in less than a day! No effort has been spared in engineering a true racing boat that looks every bit as good as it performs. Exceptional quality is evident throughout this championship-winning tunnel hull. The sponsons are built-up wood, while the hull center section is lightweight wood over foam. This design resists warping and the wood is finished in high-gloss clearcoat. Designed specifically for .21-size tunnel hulls, the VS1’s included fuel tank features 8 fluid ounces (236.5ml) of capacity. Also supplied is a mount that offers easy installation and maintenance. Serious boat enthusiasts looking for a model worthy of their competitive racing skills need look no further than the VS1!
• The water-tight radio box protects on-board equipment and allows for quick inspection without disassembly. Pull/pull cables, steering cable output guide and antenna base are included in the premium hardware package.
• The lightweight, durable ABS cowl features preinstalled doublers and foam nose block and attaches and removes easily with thumbscrews. Included decals give the VS1 a simple, competitive look that can be customized for a one-of-a-kind style.
• Included hardware meets the performance and durability requirements of aggressive competition:
Braided stainless steel pull-pull cables
Chrome clevises
Custom pull-pull wheel
Cable output
Antenna base
Remote switch assembly
Specifications:
• Hull Length: 28 in (711 mm) • Overall Length (w/O.S.® 21XM Marine Outboard): 34.75 in (883 mm) • Beam: 11 in (280 mm) • Height: 5.25 in (130 mm) • RTR Weight: 4 lb (1814 g) • Requires: 2+ channel radio w/1 high-torque standard servo and 1 mini servo, .21 outboard marine engine
AQUB0006 VS1 Competition Wood Tunnel Hull ARR
AVAILABLE: August
For more information please visit:
www.aquacraftmodels.com
