 Post subject: FUTABA MINI-MICRO, BRUSHLESS & DIGITAL SERVOS
 Post Posted: Sun Jul 27, 2008 9:35 pm
For immediate release:
**FUTABA MINI-MICRO, BRUSHLESS & DIGITAL SERVOS
The right servo for every R/C application!
BLS252 & BLS253 Brushless Heli Servos
BLS252 Specifications:
Torque: 139 oz-in (10 kg-cm) @ 4.8V; 175 oz-in (12.6 kg-cm) @ 6.0V
Speed: .16 sec/60° @ 4.8V; .13 sec/60° @ 6.0V
Size: 1.6 x .8 x 1.4 in (40 x 20 x 36.8 mm)
Weight: 2.0 oz (58 g)
BLS253 Specifications:
Torque: 117 oz-in (8.4 kg-cm) @ 4.8V; 147 oz-in (10.6 kg-cm) @ 6.0V
Speed: .13 sec/60° @ 4.8V; .10 sec/60° @ 6.0V
• 30% faster response than standard digital servos and five times longer-lasting than servos with brushed motors!
• Less susceptible to vibration and shock.
• Lower operating temperatures add longevity.
• The same power consumption as brushed digital servos with the same case size as standard-size servos.
• BLS252 with triple bearings, is designed for F3C models, BLS253 features quad-bearings and is intended for 3D helis. Both have metal gears.
BLS452 Brushless High-Torque Car Servo
Specifications:
Torque: 156 oz-in (11.2 kg-cm) @ 4.8V; 194 oz-in (14 kg-cm) @ 6.0V
Speed: .18 sec/60° @ 4.8V; .14 sec/60° @ 6.0V
• Boasts dual bearings and metal gears.
• Works well with electric and nitro cars, trucks and boats.
S3117 High-Torque Mini-Micro Servo
Specifications:
Torque: 21 oz-in (1.5 kg-cm) @ 4.8V; 24 oz-in (1.7 kg-cm) @ 6.0V
Speed: .10 sec/60° @ 4.8V; .09 sec/60° @ 6.0V
Size: .9 x .4 x .9 in (21.8 x 11 x 23.2 mm)
Weight: .3 oz (8.5 g)
• One of Futaba’s lightest servos; excellent for small electrics and foamies.
S3157 Digital High-Speed/High-Torque Micro Servo
Specifications:
Weight: .3 oz (7.8 g)
• A great choice for small electric planes and helis.
• Also available with a Micro Plug connector.
S3170G Digital Planetary Gear Retract Servo
Specifications:
Torque: 97 oz-in (6.9 kg-cm) @ 4.8V; 118 oz-in (8.5 kg-cm) @ 6.0V
Speed: .57 sec/60° @ 4.8V; .47 sec/60° @ 6.0V
Size: 1.4 x .63 x 1.0 in (34.5 x 16 x 25.8 mm)
Weight: 1.02 oz (26 g)
Rotation: 180°
• With durable metal gears and dual bearings for smooth retract performance.
• Planetary gear train allows for a compact design with incredible torque!
• The proportional S3170G servo allows easier adjustment and fine-tuning of retract operation to suit the desired application and/or useage.
FUTM0417 S3117 High-Torque Mini-Micro Servo
FUTM0522 BLS252 Brushless F3C Heli Servo
FUTM0523 BLS253 Brushless 3D Heli Servo
FUTM0553 BLS452 Brushless High-Torque Car Servo
FUTM0657 S3157 Digital Hi-Speed/Hi-Torque Micro Servo
FUTM0671 S3170G Digital Planetary Gear Retract Servo
FUTM0705 S3157M Digital Micro Servo w/Micro Plug
AVAILABLE: Early August
For more information please visit: www.futaba-rc.com
