 Post subject: **TOWER HOBBIES TURBO VEE 3 RTR
 Post Posted: Wed May 23, 2007 10:43 pm
For immediate release:
Easy electric vee made for instant action!
With the Turbo Vee 3, you won’t waste a minute of prime-time boating fun! Everything
you need is included; flotation, a powerful motor, electronic speed control with reverse,
direct drive system, radio gear and a prop – and they’re all factory installed. The ABS
hull and deck are pre-joined – no finishing required. The transmitter for the top-quality
2-channel pistol radio can be converted for right- or left-hand use. The Turbo Vee 3 also
boasts a proportional throttle and steering, steering trims, mini servo and more. Just pop
in the AA cells and it’s ready to go!
• “Chine rails” reduce drag for higher speeds and trim tabs adjust to fine-tune
handling.
• A water-cooling coil around the 540 motor helps defeat heat to keep the action
going longer.
• An included prebuilt, vacuum-formed boat stand makes the ideal place for display
or to keep the Turbo Vee 3 ready for the next run.
Specifications:
•Length: 20.5 in •Beam: 7.6 in •Includes: 2-channel radio system, motor & electronic
speed control •Requires: 6-or 7-cell flat NiCd battery, charger & 8 “AA” batteries
TOWB02A1 Turbo Vee 3 RTR A1 Retail:$149.99
TOWB02A2 Turbo Vee 3 RTR A2 Retail:$149.99
TOWB02A3 Turbo Vee 3 RTR A3 Retail:$149.99
TOWB02A4 Turbo Vee 3 RTR A4 Retail:$149.99
TOWB02A5 Turbo Vee 3 RTR A5 Retail:$149.99
TOWB02A6 Turbo Vee 3 RTR A6 Retail:$149.99
For more information please visit: www.towerhobbies.com
