A CRAWLER’S PARADISE
Irvine, CA – October 15, 2007 – Novak is taking the pain out of mixing and matching parts by combining two great products in one, ready-to-drive combo package. Novak is now offering a 55-turn brushed motor – the Fifty-Five Crawler (#3555) – to harmonize with Novak’s popular brushed ESC – the Rooster Crawler Edition (#1841). The Fifty-Five Brushed Crawler is ideal for crawling because of its precise movement control, and its high-turn count makes for exceptional torque and long-run times. The motor is also completely rebuildable with an easily accessible commutator and replaceable brushes, making maintenance a snap. In addition, Novak is pre-installing three motor capacitors to simplify the installation process, so users can be crawling in no time.
The Fifty-Five Crawler Brushed Motor (#3555) is available individually or in a Rooster Crawler Edition ESC/55 Motor Combo (#1842). Each is scheduled for shipping in mid-November 2007. For more information about this product and other Novak products, visit the Novak Web site (
http://www.teamnovak.com ).
FIFTY-FIVE CRAWLER BRUSHED MOTOR FEATURES
Specifically designed for R/C vehicles that require precise movement control
High number of turns for excellent torque and long-run times
Dual-ball bearing for smoothness and efficiency
High-strength magnet for unmatched brush motor performance
100% rebuildable with user-replaceable brushes and springs
Easily accessible commutator for easy maintenance
Direct-Solder Wiring Tabs for flexible soldering options
Novak factory-installed motor capacitors to reduce glitching
Made in Japan
Tested by Novak in Irvine, Calif.
FIFTY-FIVE CRAWLER BRUSHED MOTOR SPECIFICATIONS
Number of Turns: 55
Design: Stand-up Brushed
Input Voltage: 4-7 cells (1.2V/cell) or 2S Li-Po cells
Motor Size: 2.07” x 1.42” (52.7 x 36.1 mm)
Shaft Diameter: 0.125” (3.2 mm) [accepts all existing pinion gears]
Bearing: Standard 3/8” x 1/8”
Motor Weight: 6.03 oz. (171 grams)
Magnet: High-strength Ferrite
