For immediate release:
**NEW** AquaCraft SuperVee 27 Nitro RTR Boat
Sleek SuperVee looks...with nitro power!
If you have nitro boat enthusiasts who admire and inquire about the SuperVee 27 brushless RTR, now you can offer them that same streamlined design — with nitro power and performance! And because it’s easy to operate and comes completely assembled, even beginners can look forward to exciting off-shore racing action just minutes after taking the SuperVee 27 Nitro out of the box!
Specifications:
• Length: 27 in (686 mm) • Width: 8.13 in (205 mm) • Height: 5.5 in (140 mm) • RTR Weight: 3.4 lb (1545 g) • Includes: AquaCraft .18 engine w/tuned pipe, AquaCraft 2-channel radio w/2 servos • Requires: nitro boat fuel, fuel bottle, glow plug, glow plug igniter, 12 “AA” batteries
Check out these top-quality features!
1. AquaCraft 2-Channel Radio by Futaba®
2. AquaCraft .18 Marine Engine by O.S.®
3. Nitro boats typically create vibration, but this sturdy blue-anodized engine mount effectively isolates it.
4. The easy-access fuel tank has a screw-on lid, eliminating the need for a fuel pump.
5. Crafted from hand-laid fiberglass, the hull is painted instead of gel-coated — in one of six dazzling colors.
6. Top-of-the-line GrimRacer hardware ensures top-notch performance!
7. The Surface Drive strut assembly is made of machined aluminum, with a .150” flex drive cable and a 3/16” prop shaft, so that any prop can be used.
8. The CNC-machined aluminum deep-water rudder offers maximum strength with minimal weight.
9. A water pickup mounted on the transom channels cooling water to the engine head.
10. The mirror finish on the trim plates not only looks sharp, it also resists rust — and because the plates are stainless steel, they won’t flex when in the water. The adjustable turn fin assemblies are made of blue-anodized aluminum.
11. Boasting the durability of stainless and spring steel, the Cowl Lock system is a quick and convenient method for attaching and removing the hatch — with no loose parts to misplace.
AQUB22** SuperVee 27 Nitro RTR
AQUB2262 SuperVee 27 Nitro RTR 62-White
AQUB2264 SuperVee 27 Nitro RTR 64-Blue
AQUB2268 SuperVee 27 Nitro RTR 68-Red
AQUB2270 SuperVee 27 Nitro RTR 70-Yellow
AQUB2272 SuperVee 27 Nitro RTR 72-Green
AQUB2274 SuperVee 27 Nitro RTR 74-Orange
For more information please visit
www.aquacraftmodels.com
